This event indicates IP FDB mode has stopped, and all hardware is using LPM routing. Refer to event HAL.IPv4FIB.StrtIPFDBMode for further information. Stopping IP FDB Mode occurs only when both of the following are true: (1) The number of IPv4 routes is less or equal to the threshold, and (2) No hardware without External LPM Table is present and enabled in the system.
No remedy is necessary since this is normal.
Notice
Number of IPv4 routes is below %routeThreshold% and no active HW requires IP FDB Mode.
| Name | Type |
| routeThreshold | uInt |
